Gas leak ?
Air/flo_2
Member Posts: 3
Don't use dish washing soap on csst,not sure what type of piping you used?Had a contractor use soap on csst/trac pipe, it created pin holes in pipe.if you use soap.rinse with water and dry off piping.Or call a pro...
gas leak ?
I recently ran a branch off of my Lp gas line to feed a gas range. My wife noticed lp gas odor, so I checked all the joints w/ hercules leak detector (similar to soapy water) no leaks, still smell gas. Installed a gauge (inches of water increments) (approved for this ) on gas line and find that over a period of 3-4 hours it drops from 15" to 0". Do you have any ideas to find such a slow leak?0 -
Thicker soap (Call a Pro)
You can make it yourself using Palmolive and just a tad of water but not too much. But to do it right SHUT OFF THE GAS. Use air pressure, CO2 or Nitrogen from a bottle.
Best bet: Call a Pro, particularly your supplier.0 -
Just a thought, did the same thing in an old apartment and looked through the whole length of pipe to find it at the meter.(was just hand tight). use the soapy water liberally and shine a bright light. Pay close attention to valves. You will see the bubbles.0 -
sometimes a leak is so small
that soap bubbles/leak detector will barely show it; yet the odor will be noticeable. On the other hand, a BIG leak can overpower your olfactory senses, and you may not smell it. You can mix liquid dishsoap with windshield washer fuid in a spray bottle-then spray it liberally on each joint from all directions, then watch awhile with a mirror and flashlight. It should bubble up like foam at the leak site. Sometimes an electronic leak detector is the only way to pinpoint very small leaks. The small tubes and fittings inside the range are a very likely source of leaks.0 -
Call a Pro
Have to agree with Brad. LP is nothing to mess with. However, if you're determined to DIY, shut off the gas and pressurize the line to 15psi, then do your leak test. This is what a pro would do before placing the line into service.0 -
Call your LP supplier
they have means to find such leaks.0 -
not to split hairs but
I am a semi-retired heating contractor. I ran and press. tested the gas line branch up to and including the appliance valve, press tested to 70 psi for 3 hrs. no leaks on my work. Appliance supplier / installer made connection to range via s/s flex gas connector. I'm pretty sure that it is the range that is leaking.0 -
Are all the pilots lit
on the range???? Look out for the waist high broiler pilot people tend to forget that one.0 -
Use air to test
Use air to test
Put the soap on thick like shaving cream, wait and look with a good light.
Tim is correct
Your LP supplier MUST be notified anytime you add to or remove from the exisiting system. The incremental charge for them to perform the required leak/pressure test is inconsequential to your families safety. Please call them.0 -
Did you purge the air first?
Recheck the appliance.0 -
First call a pro
second when you did your air test did you isolate all gas valves from the test. If you exposed your gas valves to elevated pressures let the pro know what you did before he/she checks the system.
when it comes to gas especially LP, don't play, don't guess,
"Know" what you are doing or get someone who does.
Mitch S,
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 46 Industry Classes
