What is this valve for?
I thought my eyes were going! ;)
What is this valve for? it turns right to left but I don't know what it does...0 -
Looks like
an old style adjustable relief valve.
If so, whatever its on, do yourself a service and replace it.
Dave0 -
Are there two pipes running to it, or is it at the end of a run? If two pipes, it is a balancing or circuit setting valve. If it is at the end of a run, it is a relief valve as mentioned.
TimJust a guy running some pipes.0 -
only one pipe. Here are additional photo's0 -
Here are additional photos.0 -
relief valve. find out what it's set to and replace it.0 -
focus
I think the camera might need replacing too. ;-}0 -
haha
i was thinking the same thing haha
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
Ok, here we go with a diffrent camera. I am going to replace the boiler soon (with a condensing mod) but haven't decided on which one.0 -
watts # 530 adjustable relief valve0 -
As bob says,
that looks like the old Watts adjustable RV, similar to #22 or #11(not adjustable).
My pic shows another, but you had to remove the cover for the adjustment, on yours the knurled knob facilitates,, who ever knew(or was certified) to its calibration.
I still say you should replace it.
On the #22, you had to drive-in lead plugs to re-new it if it blew(used to give you extra plugs).
Dave0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
