Dry Return piping
Stewy_2
Stewy_2 Member Posts: 83
both have 1" dry returns. Can I meet the dry returns to the same vertical drip connection if I can keep the minimum "A" dimension? If so how should it be piped, I’m assuming no bull head tee. Also a question about the equalizer pipe. I wanna use 2". How far down should I go? Can I reduce it at the tee for the close nipple to the Hartford loop? Thanks
