Can someone tell me
THEY sure as heck ought to be able to...
Scanners for sale for under $100.00
ME
  • Steve Ebels_3
    Steve Ebels_3 Member Posts: 1,291
    Can someone tell me
    Does Kinko's, or other printing service, have the capability to scan a set of prints and convert it to a jpeg file? Anyone ever have this done?
  • Timco
    Timco Member Posts: 3,040
    I always have to go to an engineering company that sells transits & such. They have plan copiers & scanners and do give CD's. Here it is Monson Engineering.
    Tim
    Just a guy running some pipes.
  • Mad Dog!!!!!!!!
    Mad Dog!!!!!!!! Member Posts: 157
    Yeah STEVE...................................
    If you find the right dude/chic.....ON DUTY.....you know how bad it is out there today....BUT when you find someone who gives a ----- you in bizness. Mad Dog
  • Steve Ebels_3
    These are
    These are 2' x 3' blueprints
  • Lurkin' Murkin'
    Lurkin' Murkin' Member Posts: 136
    Man, I've never met a dude/chic - I know they exist, but guess I've just been lucky not to...
  • ER
    ER Member Posts: 27
    how perfect
    do they need to be? The quick way is to take a picture with a digital camera. If the camera isn't exactly over the print there will be some distortion of the scaling.
  • Chris_82
    Chris_82 Member Posts: 321
    yes,...
    Many times.
    First: you might want to see if your digital camera can take high resolution pictures, try with flash and without.
    second: any blueprint shop, such as Ben Franklin or whatever you have in your area, it is quite common and becoming a standard practice for large jobs.
  • Tombig_2
    Tombig_2 Member Posts: 231
    Digital Camera
    I was hand copying some info off a permit set on a job and my helper adjusted the camera resolution and shot these. At one time I had a pdf writing program so when I recieved pdf floor plans I could sketch on the 'puter my ducts layout. If it's just for future referencing the digital camera works great.
    This is a commercial buildout. The GC wanted me to drill all those joists for Ultra-Fin. He reused the old 2"X14" true dimension joists. I talked him into an overpour.
    EDIT: The pics on file are a little more manageable than the two sizes posted on The Wall attachments
  • Don \"Grumpy\" Walsh
    Don \"Grumpy\" Walsh Member Posts: 184
    Yepper, I get it done often
    I use a reprographic service here that will scan my large prints and convert them to jpeg for me. I usually get them placed on a CD and then I can alter the drawings with my auto-cad program. After the alterations, they will reprint them for me with all the changes. Not cheap, but sure worth it for the convenience. I had planned on buying a scanner until I heard the $13,000 price tag. For the $75 or so I pay them, I'll stick with their services.
