radiant loop flow meter(gauge)
Todd S_6
Member Posts: 3
size pipes do you have then? !/2" stubs feeding 3/8"tubing?? There may be something available, I'm surprised no one else has thought of something yet....
flow control gauge for radiant loop
recently did a radiant floor job with three 1/2 pex loops off a copper manifold, 2 loops are equal in size one is about 3/4 to 1/2 the size of the other two.have valves on the manifold and tried cracking it down to even out loop flow but cant seem to get it perfect, does anybody know of a gauge or meter that i can crimp into the pex lines,or one that can be sweat on to the maifold.any suggestions would be greatly appericated
thanks eddie0 -
What
brand of tubing & manifolds are you using? Some companies have flowmeters that go right on the manifold.0 -
yeah i know but it was a copper manifold with valves and pex adapter on it,not one of the ones you can screw the meter on0 -
1/2
1/2 crimp barb with 1/2 pex0 -
suggestions
any body else have any suggestions or ideas i can use for this balancing problem thanks
eddie0 -
balance
can this be balanced by measuring the temperature drop in the loops?-hopfully all would be the same-nbc0 -
lo-temp flow meter
Dwyer LFMA's are relatively inexpensive, but with ABS and polycarbonate construction, can't be used over 140F.
dwyer-inst.com0 -
Copper manifolds...
...using 1/4 turn ball valves cannot be balanced. Radiant manifolds with adjustable flowports can.
replace the manifold wit a flow meter type
Caleffi has a cute little 1/2" flow meter, it's new and may not be on the shelves yet. probably quicker and easier to change the manifold. at least one side. the ball valves, while not ideal, could be adjusted if you had meter to watch.
hot rodBob "hot rod" Rohr
- 167 Indoor-Air Quality
