White House
You know what happens if I tell you!
  • mikea23
    mikea23 Member Posts: 224
    white house
    I had a customer ask me what kind of system is in the White House. He explained that he worked there years back and always found it comfortable.
  • jp_2
    jp_2 Member Posts: 1,935
    in theory
    its an ideal system, but the politicians keep screwing it up.
    too bad government couldn't run off of outdoor reset.
  • mikea23
    funnny that was my ans to him when he asked
  • hvacfreak
    hvacfreak Member Posts: 439
    I have a job in the White House " complex " ( some townhouses right across PA. Ave. ). District steam to shell and tubes is the heat. AC I can't say...I'd imagine Trane Chilled water from somewhere , but that's just a guess. Controls are " generic " on my project ( I could provide a better product by myself ) , I hope the " Big House " has better.
  • Timco
    Timco Member Posts: 3,040
    I believe it's a system of 'checks' and 'ballvalves'...or is it balances...
    Tim
    Just a guy running some pipes.
  • Dry Steam
    Dry Steam Member Posts: 32
    ballvalves
    You mean screwball valves don't you?
  • David Nadle
    David Nadle Member Posts: 624
    I don't know what type of system it is but it certainly produces a lot of hot air.
  • John Mills_4
    John Mills_4 Member Posts: 43
    Yorkie
    Seems to me I recall seeing a York ad where they say their chillers cool the WH and capitol.
  • Fred Harwood_2
    Fred Harwood_2 Member Posts: 196
    hot air
    That's Congress, right?
  • World Plumber
    World Plumber Member Posts: 389
    La Masion Blanche
    La Masion Blanche (the White House) has hot water heat with thermostatic valves on constant circulation.
  • hvacfreak
    ok...
    what heats the water ? Is it the same district steam I'm getting across the street ?
    nevermind...I was just thinking of the 1 inch " man-bars " I had to install in 6 inch round duct in Arlington , VA. I'm sure the White House is a " stand alone " system with security measures I can't even begin to imagine.
  • white house
    ever notice that the econo-politicians, in describing our present situation, use mainly hydronic terminology:
    cashFLOW, LIQUIDity, downward PRESSURE?
    obviously whoever is put in charge of those matters should be required to take several of dan's courses, and then go out on diagnostic calls with one of the wallies.
    that would set up his/her brain for real work!
    world plumber can provide the details from his french chateau on the french politician who had been a hydronics expert in real life!--nbc
  • World Plumber
    14 wall mount boilers
