Any opinions on the Wilo 3 speed pumps?
Here's The Star Pumpo
http://www.apiofnhanddeltat.com/na_star_brochure_2.pdf
Here's the rest
http://www.apiofnhanddeltat.com/api_10_08_327.htm
Rick
  • SciGuy
    SciGuy Member Posts: 15
    Wilo 3 speed pumps
    It would seem that they are new to the US market but what is feeling in regards to the Wilo 3 speed pumps?
    I am specifically interested in the WILO CLASSIC STAR S16BFX BRONZE CIRCULATOR. It looks as if they have a bronze 3 speed very price competitive with Grundfos as well as Taco's 007 Bronze single speed.
    I have not been able to find a pump curve for this unit and wonder how it compares to the Taco 007.
    Thanks for any informed replies.
  • nice unit
    We have been using them for 2 years an d have had no problems. They do not come with a internal flow check so remember one when installing. You should look at the ECO or Stratos pump they are amazing!
  • Is wilo
    making variable speed pumps? If so, got a link?
  • Brad White_202
    Brad White_202 Member Posts: 105
    Yes,
    The Stratos Eco which is a Star 16 with a drive is at least one that is comparable to a 007 and 15-58, that range. Their regular Stratos line covers slightly larger sizes. I have use a couple on a large house and they work great, allowing us to dial in the right pressure and flow we need.
  • Thanks Brad...
    I'll take a look at them.
  • Timco
    Timco Member Posts: 3,040
    Are the Wilos at all comparable to the 007's & 15-58's price wise? Do many use them for residential? Lifespan difference? I would need to offer the customer something to offset a greater price...
    Tim
    Just a guy running some pipes.
  • tccoggs
    tccoggs Member Posts: 9
    About the same price wise:
    http://www.patriot-supply.com/products/showitem.cfm/177248
    One difference is that there is no IFC, Wilo puts the flow check in the flange as an option, which might not be a good thing for the guys that love the Isolation flanges.
  • Flanges
    Wilo offers isolation flanges with or w/o check valves.
    The flanges rotate as well.
    Hope this helps.
    Mark H
  • tccoggs
    Thanks Mark, I haven't come accross them yet. Will have to keep an eye out.
