Any opinions on the Wilo 3 speed pumps?
Supply House Rick
Member Posts: 1,404
Here's The Star Pumpo
http://www.apiofnhanddeltat.com/na_star_brochure_2.pdf
Here's the rest
http://www.apiofnhanddeltat.com/api_10_08_327.htm
Rick
Here's the rest
Rick
Wilo 3 speed pumps
It would seem that they are new to the US market but what is feeling in regards to the Wilo 3 speed pumps?
I am specifically interested in the WILO CLASSIC STAR S16BFX BRONZE CIRCULATOR. It looks as if they have a bronze 3 speed very price competitive with Grundfos as well as Taco's 007 Bronze single speed.
I have not been able to find a pump curve for this unit and wonder how it compares to the Taco 007.
Thanks for any informed replies.0 -
nice unit
We have been using them for 2 years an d have had no problems. They do not come with a internal flow check so remember one when installing. You should look at the ECO or Stratos pump they are amazing!0 -
Is wilo
making variable speed pumps? If so, got a link?0 -
Yes,
The Stratos Eco which is a Star 16 with a drive is at least one that is comparable to a 007 and 15-58, that range. Their regular Stratos line covers slightly larger sizes. I have use a couple on a large house and they work great, allowing us to dial in the right pressure and flow we need.0 -
Thanks Brad...
I'll take a look at them.0 -
Are the Wilos at all comparable to the 007's & 15-58's price wise? Do many use them for residential? Lifespan difference? I would need to offer the customer something to offset a greater price...
TimJust a guy running some pipes.0 -
About the same price wise:
http://www.patriot-supply.com/products/showitem.cfm/177248
One difference is that there is no IFC, Wilo puts the flow check in the flange as an option, which might not be a good thing for the guys that love the Isolation flanges.0 -
Flanges
Wilo offers isolation flanges with or w/o check valves.
The flanges rotate as well.
Hope this helps.
Mark H0 -
Thanks Mark, I haven't come accross them yet. Will have to keep an eye out.0
- 117.6K All Categories
- 82.8K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 402 Carbon Monoxide Awareness
- 8 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 107 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 679 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.3K Strictly Steam
- 2.9K Thermostats and Controls
- 48 Water Quality
- 31 Industry Classes
- 65 Job Opportunities
- 11 Recall Announcements
