Which T-stats from Honeywell work with 3-wire WR zone valves?
carol_3
Member Posts: 397
You can use the TH5110 non-programmable or the TH8110 programmable. Go into installer setup to select 3-wire control. You can look at both at http://customer.honeywell.com. Scroll all the way down to the bottom right corner. In the white box, type th5110, and click on the arrow. On the page that comes up, scroll down to installation instructions and click on pdf to the left.
White-Rogers 3-wire Valves
Which Honeywell T-stats are going to work with power-open/power-close 3-wire Zone Valves?0 -
Regarding stats
I am pretty sure you can program the vision pro to control these. There was a thread not to long ago that Bill W replied to. Look at the manual and I think you will find this. Good luck, Tim0 -
VP
The Vision Pro can do it in a heat only application. Option 170, selection 5.0 -
stay w/ wr stats0 -
Thanks for the Info
Many hapless customers are ordering stats from the internet or buying them at the Big Box; expecting big savings from nite setback-only to find frozen pipes in the morning. Bad advice being given at the Orange Smock Dept. Store. Thanks Carol!0 -
I don't know how many times I have installed these stats and have never noticed that they can be used on a 3 wire. Cool! I have a job where I can use this info.
Dave StromanThere was an error rendering this rich post.
Best kept secrets!0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
