rotten egg smell from radiant floor heating system
As usual. I'd bet Hot Rod hit it right on the head. Pull out that anode rode and use fresh water.
  • Jim Hall
    Jim Hall Member Posts: 36
    rotten egg smell
    we have a radiant floor heating system with 80 gallon water heater and a recirc pump. It is a closed system and drained off a little water from system to lower operating pressure and got horrible egg smell What is cause? Is this normal? What can we do about this if anything?
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    Yes, use Airfreshers, Just Kidding, Is the system heated by a Boiler or waterheater? . I did not understand the post!..... Sometimes if you use well water you can get some Minerals that when heated do all kind of things,What i use in my systems is a system cleaner and then a system treatment(Rhomar) Start with checking the PH maybe tap some fluid.Are you a" heating guy" or HO.?
    hot_rod Member Posts: 26,638
    what type of tube?
    Is it rubber hose by chance? Or if it is pex, is it a barrier type pex.
    Also the anode rods in water heaters can sometimes cause that odor.
    hr
  • yep der,
    i was about to ask the same/a similar question; smell from the drain off? 'sulfer' well? if so, there are some formulas out there, u of pa paper?, that tells ya in detail how to shock a well with clorox in order to get rid of those easter fart smells
  • Jim Hall
    rotten egg smell
    should you take anode rod out of a closed radiant floor heating system? we are on a well but never get that smell from our domestic water system. System has been shut off for about 6 months. Not normally a problem and I don't really care what it smells like as long as it isn't hurting anything. I bled off a little pressure and noticed the foul smell.
    smelly info
    www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/water-heater-odor.html
    I doubt the smell is going to cause a problem.
    Is the heater connected to the potable water with a fill valve? Be sure you have an approved backflow device to prevent that water from entering your water system.
    hr
  • yep hr,
    that was my other head scratch; heater/potable connection with no bflow p
  • Jim Hall
    yes there is a double backflow prevention valve since there is a bit of food grade antifreeze in system as well
  • Derheatmeister
    Well??
  • ok, double backflow
    is it an indirect wh and boiler, or a heat exchanger/
    boiler system?
    an 80 gallon WH
    as the dedicated radiant source as I read it?
    hr
  • Derheatmeister
    How about some pictures of the System. I think i am not the only one that does not get you post ! there is just not enough information to figure it out, and again is the water from a well or from city water?. Was the system cleaned from the manufactures oil?. Is the system heated by a boiler? OR by a water heater.? Do you have Rubber hose as infloor tube. Oxygen barrier? Or none Oxygen Barrier. Too many things , No Feedback! I guess you maybe do not know the Answer to some of this but PIX go a long way!
