Runtal towel warmer in gravity system?
gasfolk
Member Posts: 392
and a Runtal panel rad for supplemental heat in a rear entryway, and even with 1/2 inch supply and return it heats to our needs. We did take a supply and return off the gravity mains for a pumped zone (with Tekmar radiant floor controller) to radiant heat for the kitchen and a bathroom with ceramic tile floors, and if you can, it is definitely worth it.
Just our experience. YMMV.
gf
gf
Hello all- first, many thanks from this lurker for your expertise! I've only recently found this board and have already learned some details about my heating system that I just hadn't been able to figure out...
For now, I have just a quick newbie question, I'm sure I'll be back with some other stuff later... a rough outline of my system is:
American Radiator Company gas-fired boiler
gravity system, no pump, although there is a
Honeywell Heat Generator (seems to be working- pressure gauge on system shows 10PSI when system on)
Double risers/returns, largest 2", other 1.5"
Radiator pipes either 1" or 3/4" depending on rad size.
System currently only has rads on one floor, 2nd floor rads and piping were removed long before I got the house. 2nd floor heat currently lame forced air. Blech.
I usually run ~150 degree water, this works fine for all but the coldest spells here in Nashville TN
system works great as-is. I've only had to replace the main gas valve (was a Detroit Controls unit, mica plate & everything- fascinating piece of technology) and add a Honeywell T775 for control.
I'm in the midst of bathroom renovations and am toying with the idea of adding towel warmers/incidental heat rads to both bathrooms (1st and 2nd floors) since I have the walls open and can re-pipe. I have the original taps available on the supply riser and return: mid-pipe for 2nd floor, 45 degree/top pipe for 1st floor.
Do the Runtals or similar panel rads have enough water volume to work properly w/o a pump? Would the 1/2" pipe size effectively work as a plate restrictor on the 2nd floor unit?
The bathrooms are small, so they don't really need much in the way of real heat- the 1st floor has been fine without any heat actually in the bathroom, the 2nd floor has air heat but the wind chill practically negates it.
Comments? Suggestions?0 -
We have gravity without a pump...
and a Runtal panel rad for supplemental heat in a rear entryway, and even with 1/2 inch supply and return it heats to our modest needs (haven't put a thermometer to it to calculate btu output). We did take a supply and return off the gravity mains for a pumped zone (with Tekmar radiant floor controller) to radiant heat for the kitchen and a bathroom with ceramic tile floors, and if you can, the floor warmth on chilly days is definitely worth the effort.
gf0
- 85.7K THE MAIN WALL
- 50 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 852 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
