flash heating with no recirc
JSPAK
Member Posts: 25
but for a hosital to at some points (maybe 7 floors away)to need that hot water immediatly .... doesnt sound right to me
anyone ever hear of a system(domestic water)where a on demand hot water heater(steam is used to make 140 degree water.)is used in a large builing (7 story hospital) and there is no storage tank or recirculating line.At each floor there is a mixing valve or tempuring valve.hmmmmm i havent seen it but was told about it.0 -
Yep...
I worked at Symphony Hall in Boston where such a unit is used for showers... Basically a very small shell and tube HX... They had pneumatic controls and were a little labor intensive to keep running.0 -
Make me do the work will ya?
Like this? http://www.cemline.com/brochures/seh.pdf
The units I worked on were almost identical except for the updated controls...
Good luck, remember: Google is your friend!0
- 62 Biomass
