climate panel groove lube
J.C.A._3
Member Posts: 2,980
Has aluminum in the silicone. The thought is that it will help transfer the heat a little better, along with the aluminum under the panels.
I'm not sure how much of a difference it makes, but in a pinch...I've used regular silicone and haven't heard any complaints. Chris
groove lube
Does anyone know if there is a difference between viegas groove lube and regular 100% silicone? Thanks.0
- 167 Indoor-Air Quality
