climate panel groove lube
J.C.A._3
J.C.A._3 Member Posts: 2,980
Has aluminum in the silicone. The thought is that it will help transfer the heat a little better, along with the aluminum under the panels.
I'm not sure how much of a difference it makes, but in a pinch...I've used regular silicone and haven't heard any complaints. Chris
  • Tom Hopkins
    Tom Hopkins Member Posts: 554
    groove lube
    Does anyone know if there is a difference between viegas groove lube and regular 100% silicone? Thanks.
