freidrich PTACs
[Deleted User]
and even found documentation from the consumer safety protection agency and freidrich themselves regarding the potential for overheating/fire on very specific units; model and serial numbers to boot. but i was hoping to get some 1st hand exp on the whole mess. customers/insurance companies want to blame the last person that had their hands on it; nothing new
has anyone had fires
with these units due to fan switch/heat pack problems?0 -
Hi Mike
Carrier Corp. has a recall on their P-Tak's due to fire hazard. You might want to see if the inerts are made by the same company.
Mike T.0 -
Mike, My thoughts on the Ptak
I never liked the fact that the Carrier models, after satisfying shut down the fan immediately. The snap disc are 1 timers and usually kicked out due to this reason. You can pop, or reset in by taking foil tape over the metal p[art of the disc and quickly pulling it off. Not that this is normal, but nonsense trips are a pain on the @#*...
Mike T.0 -
sheesh
what a cheezy set up. and we're looking at whose 6-figure responsibility it'll be0 -
Oh well
Since they are only about 3 to 6 KW, and the hotel Voltage is 277 which, by the way hurts when Zapped,... Hurts..:-) . Anyone can contest the design of any piece of equip. and since it's a package unit, don't fret. That's like installing a RTU and having it burst into flames due to questionable design. There's nothing to worry about till there's something to worry about. At least that's what Grand Pa.. used to say.
Mike T.0
- 15.8K Strictly Steam
