heat loss question
hot_rod
hot_rod Member Posts: 26,579
there are times with todays super insulated homes that the DHW load exceeds the heat load.
Large tubs, fast fill valves, body sprays are areas to watch.
hr
  • ed m
    ed m Member Posts: 65
    heat loss DHWH
    when do a heat loss calculation, do i have to add in or consider additional btus for an indirect heater.
    thanks for your help
    eddie
  • kevin coppinger_15
    kevin coppinger_15 Member Posts: 35
    I don't...
    unless there is a huge hot water demand. A priority relay is usually all that is needed. kpc
