heat loss question
hot_rod
Member Posts: 24,497
there are times with todays super insulated homes that the DHW load exceeds the heat load.
Large tubs, fast fill valves, body sprays are areas to watch.
hr
hr
heat loss DHWH
when do a heat loss calculation, do i have to add in or consider additional btus for an indirect heater.
thanks for your help
eddie0 -
I don't...
unless there is a huge hot water demand. A priority relay is usually all that is needed. kpc0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
