Infloor Pump control
the old Infloor Zone Control Module, I don't think Infloor supports them any longer. Replace it with a new pump and mixing valve (Taco i-series or equal).
See photo.
  • Rick_71
    Rick_71 Member Posts: 1
    Where can I find an "Infloor" manifold pump thermostat/control or an alternative retro-fit?
    Any help would be appreciated.
    Thanks
    Rick
  • infloor pump control
    Hello. What are you trying to achieve?
  • If you mean
    the Infloor Zone Control Module, forget about it. I don't believe Infloor supports these anymore. You have to remove it, install a new pump and mixing valve (Taco i-series or equal).
    See photo.
  • Gary Jansen_4
    Gary Jansen_4 Member Posts: 77
    an alternative
    I had a series of apartment buildings with the infloor packages failing. I used the Taco Radiant Mixing Blocks (RMB) when I was a contractor with good success.
