Infloor Pump control
Alan(OnVacationInOregon)Forbes
Member Posts: 232
the old Infloor Zone Control Module, I don't think Infloor supports them any longer. Replace it with a new pump and mixing valve (Taco i-series or equal).
See photo.
See photo.
Where can I find an "Infloor" manifold pump thermostat/control or an alternative retro-fit?
Any help would be appreciated.
Rick
infloor pump control
Hello. What are you trying to achieve?0 -
If you mean
the Infloor Zone Control Module, forget about it. I don't believe Infloor supports these anymore. You have to remove it, install a new pump and mixing valve (Taco i-series or equal).
See photo.0 -
an alternative
I had a series of apartment buildings with the infloor packages failing. I used the Taco Radiant Mixing Blocks (RMB) when I was a contractor with good success.0
- 114 Geothermal
