Fyrite Pro rental
Dirk Wright
Member Posts: 142
I have a Fyrite Pro 125 + the smoke tester, but no printer. I'm getting the Fyrite Pro calibrated right now. It needed a new oxygen sensor ($$), so I was thinking that I may be interested in renting this kit out to service techs, but I don't know what is involved, if anything, and how much to charge. I was thinking that I should require at least a 500$ deposit and charge maybe 100$ per week. I'm only going to use it a few times per year, and the O2 sensor goes bad in less than two years regardless of whether or not you use the instrument. Any ideas on how to do this? I'm not a business, just a private owner.
here in BC
that machine rents for $150 the first day out, $100 each day after that. A credit card is required to secure the rental.0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
