Pipe dope
Tony Conner_2
Member Posts: 443
...easy to spell incorrectly. There's no "E". Try www.xpando.com
Pipe Dope
What is a good leak free pipe sealant to use on copper male adapters screwing into a cast iron boiler?0 -
PERMATEX
I am a big fan....
of teflon tape and whitlam blue magic. Permatex is ok but gosh its messy. Thats why I call it permanent-tex...you get it on you, its permanent. kpc
sealant
Megaloc0 -
Not approved but,,,
I've been using GE 100% silicone for all things hydronic for over five years now over a 3-wrap of teflon tape. So far - so good. I really like the way things fit-up with this method. (not for gas!)
Rectorseal #5 is the old standby and it's never let me down but, it's hard to get off hands & pants. Think Dan has a section to the left that talks about pipe sealant.
Wallace Radiant Design
I like the Permatex too
on fittings you know you never need to take apart again .
For everything else it's 2 or 3 wraps of Teflon on the first couple of threads , then Rectorseal #5 over the Teflon . I also throw some sealant on the inner threads of everything above 1 inch - better to be safe than sorry .
We don't usually put male adapters directly into a boiler.
Teflon and Rectorseal. Exactly as Ron Jr. does.
We keep Permatex on hand just in case, but rarely have to use it.
Leak lock on oil line fittings from tank to burner.
Rectorseal Number 2 for oil fill and vent.
I want to try the Loctite 55 string, and Expando. Can't find Expando anywhere. Does someone want to send me a can?
I have money. Green money.0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
