Consolidated Furnaces
Glen
Glen Member Posts: 854
but this is what is readable
Furnace – Consolidated Industries
Model – MDA 080 PH3R
Ser – 950927375
Smart valve # - SV 9500 8619 (LPG)
  • Glen
    your experiences???
    I thought it would be a simple service call to a summer cottage - no heat. Turns out to be a consolidated furnace - and on checking for a gas valve replacement - I am told it is no longer produced and I am advised to shut it down and disable because of the risk of spontaneous fire. Would any one have further info on this?
  • Mitch_4
    Mitch_4 Member Posts: 955
    Consolidated
    Went into receivership around 1995, their interests were picked up by Texas Furnace.
    This link is the contact info..maybe they can help. I know I can still get parts here in Ontario through Olsen, they carried the Mini Max made by consolidated.
    http://www.texasfurnace.com/Contacts.htm
    Mitch
  • Glen what is the
    make and number of the gas valve, maybe I can help you find a replacement?
  • Jason_25
    Jason_25 Member Posts: 22
    be sure to check HE for leaks - very common on these where the secondary connects to primary exchanger as for gas valve isn't that a standard smartvalve
  • Steve Ebels_3
    Steve Ebels_3 Member Posts: 1,291
    Your local Johnstone
    Johnstone has a cross for that valve. I service more than a few of that brand around here and the only thing I have trouble finding is the condensate trap. Pretty much everything else is standard off the shelf type parts. They did have a fair amount of HX problems due to the joint between the primary and secondary HX coming apart.
  • Glen what is the letter
    after SV9500 is it an M or H. That is a Generation I SmartValve (no longer made) which is replaced by a Generation II valve.
  • The best I can come up with is
    a replacement by SV9501M 8129.
  • Glen
    the letter -
    was just a dark smudge. Unable to read it. The GV you suggest - is this a generic smart valve?
  • I took your numbers and cross
    referenced to Honeywell cross reference manual I have.
  • Glen
    thanks
    I will order one this morning.
