Using R-11 Fibreglass to insulate steam pipes
RTB
Member Posts: 8
Big professional plumbing supply house is what you need. Hit the nearest big city's yellow pages, measure your pipes diameter, and get on the phone. UPS works wonders.
I have 3" copper pipes near the boiler (Hartford Loop?), and 3" cast iron mains. The copper pipes are not insulated. Sections of the cast iron main are insulated with asbestos.
I have tried to locate clamshell type insulation in the Albany, NY area, without success.
Is it safe and recommended to use regular R-11 Owens Corning Fiberglass insulation (the type normally used in walls)?
I would like to reduce my bill (which was high last winter) but I don't want a fire hazard instead.
Thanks for your advice
Rickey0 -
> I have tried to
> Is it safe and
> walls)?
> hazard instead.
> Thanks for your
> advice
> Rickey
- 121 Chimneys & Flues
- 15.8K Strictly Steam
