Using R-11 Fibreglass to insulate steam pipes
RTB
Big professional plumbing supply house is what you need. Hit the nearest big city's yellow pages, measure your pipes diameter, and get on the phone. UPS works wonders.
I have 3" copper pipes near the boiler (Hartford Loop?), and 3" cast iron mains. The copper pipes are not insulated. Sections of the cast iron main are insulated with asbestos.
I have tried to locate clamshell type insulation in the Albany, NY area, without success.
Is it safe and recommended to use regular R-11 Owens Corning Fiberglass insulation (the type normally used in walls)?
I would like to reduce my bill (which was high last winter) but I don't want a fire hazard instead.
Thanks for your advice
Rickey0 -
> I have tried to
> Is it safe and
> walls)?
> hazard instead.
> Thanks for your
> advice
> Rickey
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
