Using R-11 Fibreglass to insulate steam pipes
RTB
RTB Member Posts: 8
Big professional plumbing supply house is what you need. Hit the nearest big city's yellow pages, measure your pipes diameter, and get on the phone. UPS works wonders.
  • Rickey
    Rickey Member Posts: 2
    I have 3" copper pipes near the boiler (Hartford Loop?), and 3" cast iron mains. The copper pipes are not insulated. Sections of the cast iron main are insulated with asbestos.
    I have tried to locate clamshell type insulation in the Albany, NY area, without success.
    Is it safe and recommended to use regular R-11 Owens Corning Fiberglass insulation (the type normally used in walls)?
    I would like to reduce my bill (which was high last winter) but I don't want a fire hazard instead.
    Thanks for your advice
    Rickey
  • michael_15
    michael_15 Member Posts: 231
    > I have tried to
    > Is it safe and
    > walls)?
    > hazard instead.
    > Thanks for your
    > advice
    > Rickey
