tekmar 260
Joe Brix
Member Posts: 626
because it's set to a specific outdoor temp value and the outdoor temp sensor says its above that. If yo want the heat to fire now, you'll have to go into the configuration mode and raise the WWSD temp setting.
I have a tekmar 260 control and right now i have it in wwsd
warm wheather shut down and now its heating season.Should i have to change it so it is not in wwsd.
thanks jim0 -
Jim...
...are you using an Indoor Air Sensor (terminals 17 and 18)?
Mike0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
