umm...Dan?
Mitch_4
Member Posts: 955
Um..Dan?
your article states the following (cut and pasted) "and he decided to make the boiling point of water zero degrees and the freezing point of water 100 degrees"
Freezing was zero, and boiling 100 inthe °C scale..I am unaware of anyone using a lower number in any system for the boiling point (at lest in any system that caught on.
I know you are generally infallible (to the point I am begining questioning the °C scale...and I am a Canadian!)
But can you clarify?
You repeat that statement later in the article..
Mitch
Mitch
I looked Paul
and even the almighty Wiki says freeze = 0 , boil = 100.0 -
sometimes
you can't find that screw drivers thats right in front of you??
I'd assume dan just didn't 'see' the mistake right in front of him?0 -
Maybe
...this is the Bizarr-o World.
That would explain everything.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
dan?Mistake?
Like I said..he is the soul of accuracy..I began to question myself I trust his word so much!!! (seriously!!)0 -
AAAHHH!!
Maybe he did the research while shaving, and the bathroom mirror reversed what he was seeing!!0 -
Celsius
Keep Reading.....
Under History:
"In 1742, Anders Celsius (1701 1744) created a "reversed" version of the modern Celsius temperature scale whereby zero represented the boiling point of water and one hundred represented the freezing point of water."
Looks like Dan got it right. - DF
NOVA
It was also mentioned on the NOVA show " Absolute Zero" on PBS that when Celsius first created his thermometer boiling was zero and 100 was freezing. It was later reversed to match the other popular thermometers of the time0 -
Source
is Heating and Ventilating Buildings by Rolla C. Carpenter, M.S., C.E., M.M.E. He was the Professor of Experimental Engineering at Cornell University and was also one of the early presidents of the American Society of Heating and Ventilating Engineers, which became ASHRAE. He wrote this book in 1901. I've attached the pages for your files.
In 1742, Celsius was using zero as boiling and 100 as the freezing point. See page 2 of the PDF.Retired and loving it.0 -
SEE..I told you Dan is NEVER wrong!
Thanks for the information...messes my mind though0 -
Dan thought.....
.....he was wrong once.
Turned out he was mistaken........0
