umm...Dan?
Mitch_4
Mitch_4 Member Posts: 955
Um..Dan?
your article states the following (cut and pasted) "and he decided to make the boiling point of water zero degrees and the freezing point of water 100 degrees"
Freezing was zero, and boiling 100 inthe °C scale..I am unaware of anyone using a lower number in any system for the boiling point (at lest in any system that caught on.
I know you are generally infallible (to the point I am begining questioning the °C scale...and I am a Canadian!)
But can you clarify?
You repeat that statement later in the article..
Mitch
  • Paul Fredricks_5
    Paul Fredricks_5 Member Posts: 132
    Look under history in this link:
    http://en.wikipedia.org/wiki/Celsius
    More things I didn't know.
  • Mitch_4
    I looked Paul
    and even the almighty Wiki says freeze = 0 , boil = 100.
  • jp_2
    jp_2 Member Posts: 1,935
    sometimes
    you can't find that screw drivers thats right in front of you??
    I'd assume dan just didn't 'see' the mistake right in front of him?
  • JohnNY
    JohnNY Member Posts: 3,341
    Maybe
    ...this is the Bizarr-o World.
    That would explain everything.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • Mitch_4
    dan?Mistake?
    Like I said..he is the soul of accuracy..I began to question myself I trust his word so much!!! (seriously!!)
  • Mitch_4
    AAAHHH!!
    Maybe he did the research while shaving, and the bathroom mirror reversed what he was seeing!!
  • Dan Foley
    Dan Foley Member Posts: 1,268
    Celsius
    Keep Reading.....
    Under History:
    "In 1742, Anders Celsius (1701 – 1744) created a "reversed" version of the modern Celsius temperature scale whereby zero represented the boiling point of water and one hundred represented the freezing point of water."
    Looks like Dan got it right. - DF
  • Rich L.
    Rich L. Member Posts: 414
    NOVA
    It was also mentioned on the NOVA show " Absolute Zero" on PBS that when Celsius first created his thermometer boiling was zero and 100 was freezing. It was later reversed to match the other popular thermometers of the time
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    Source
    is Heating and Ventilating Buildings by Rolla C. Carpenter, M.S., C.E., M.M.E. He was the Professor of Experimental Engineering at Cornell University and was also one of the early presidents of the American Society of Heating and Ventilating Engineers, which became ASHRAE. He wrote this book in 1901. I've attached the pages for your files.
    In 1742, Celsius was using zero as boiling and 100 as the freezing point. See page 2 of the PDF.
    Retired and loving it.
  • Mitch_4
    SEE..I told you Dan is NEVER wrong!
    Thanks for the information...messes my mind though
  • John Starcher_4
    John Starcher_4 Member Posts: 794
    Dan thought.....
    .....he was wrong once.
    Turned out he was mistaken........
