Installing tekmar 510
Steve D_7
Member Posts: 10
I am interested in the 510 thermostat and have some install questions.
My current programmable is 2 wires. Do I need 4 wires or can the tekmar work with 2? The boiler / pump control is integrated in my boiler. Where to the 24V contacts tap on a W-M transformer - there are many taps?
How does this compare to the honeywell overall - programming and system control?
Thanks, I know this is the busy season but appreciate any help.
Steve
Steve
atleast 3
you'd need at least a 3 wire.
4 Wire if the heat relay is to be dry contact.
it needs constant power (C&R), thats 2.
and you can jump C to one side of heat relay and run the other side of heat relay back to trigger device (min. 3 wire total)
gl.
EIN
tekmar vs visionpro
I do have 3 wires on my stats.
As I see the difference, tekmar has the ability to use an "auto" setting for cycles per hour. The Honeywell requires a setting. Which is preferable?
The tekmar is PI control. Is the HW PI or PID? Does tekmar lose its settings when power goes out?
What do I give up with different versions of the vision - pro vs retail.
Thanks
Steve0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
