An ECM circulator question......hb
Mark Hunt_3
Member Posts: 184
Hi Jeff.
The Stratos and Stratos ECO have built-in, self cleaning filters for just the reason you mentioned. The Stratos has been in use since 2001 in Europe and 2004 in North America with excellent track records.
The engineers at Wilo took all of this into consideration when they designed the Stratos series circulators.
I you are going to ASHRAE, stop by our booth. We will have cut-away models of the circulators there for all to take a look at.
Hope this helps.
Mark H
Hope this helps.
Mark H
...or observation.
What are the chances of an ECM pump failure in an older radiator system loaded with iron oxides? I ask because the magnet rotor are pretty large creating a magnetic field more intense than what we are used to. Could the pump attract enough iron from the water to actually stop working?
The ECM achilles heel?
hb0 -
Good question hb
And it's one that I would have absolutely no way of answering. Are you talking floaty bit and pieces of ferrous material or microscopic suspended solids?0 -
ok,...
so where are you finding these circ's?
why do i always feel like the world is passing me by *~/:)
i know it is chilly in Florida buh this place takes cold to a Whol Nother Laval
Would the particles be aligned to Magnetic North? you gotta ask yourself
now if you sent one to me an my mouse , Wilo ,i could do this kinda test for you for free..,
Send Rocky one and we could compare notes
Weezbo
I am looking into this.
I will get back to you with more info as soon as I have it.
Mark H0 -
Weezbo
This is the Wilo rep in Alaska.
Roth Sirianni LLC
8040 King St.
Anchorage, AK
I can e-mail you the phone number if you need it.
Mark H0
