Loud Rinnai
JackFre
JackFre Member Posts: 225
and take a gander inside. Perhaps something got pulled in during install. Call 1 800 621-9419 and follow the directions for tech service. I agree that it is probably vent related. You might disassemble the vent, carefully inspect and re-install. Disconnect the vent and see if it quiets down. Also, removing the vent motor is a snap. remove the bellows, the two obvious screws, pull the wire off and it is in your hands. If you do this, be very careful when reassembling that you make sure the tongue in the back is engaged prior to putting the screws back in. They are typically very quiet.
  • Brad_9
    Brad_9 Member Posts: 29
    Loud Rinnai
    I installed a Rinnai tankless water heater to try out before recommending to others. It seems rather loud to me, it's by far the loudest piece of equipment in our house (about 4 or 5 times louder than the fridge). Fortunately it's in our utility room, so it's not a big issue for us, but I'm not sure I would recommend these to other customers if they are really that noisy. I'm wondering if this is normal? The sound appears to be the burner fan. This is the indoor sealed unit, and is two years old and was noisy from day one. Thanks
  • Nron_13
    Nron_13 Member Posts: 164
    cumbustion fan
    the fan must be unbalanced as the ones i have seen are quiet in the house
  • rob brown
    rob brown Member Posts: 69
    you may want to check the vent connections. our co. installed 4 of these units in identicle (sp?)condos. got called to check noise from 1 unit. found that vent pipe was not fully seated at one joint, corrected, and noise was gone. rob
  • Scott Gregg
    Scott Gregg Member Posts: 187
    You have something wrong!
    I have never seen a loud Rennai. Something IS wrong with it. Call Rennai and try out their customer service department.
  • Ranger
    Ranger Member Posts: 210
    Jeff Oliver
    joliver@rinnai.us Jeff should be able to help.And Rob is exactly right.The venting is usually the culprit with noise issues.
