cleaning one pipe steam
John_101
Member Posts: 12
I used boiler cleaner. I dumped the system. Return lines the boiler etc. Changed all the lower valves so they worked.
Filled the system several times to flush.
I then added boiler steam treatment HD had it.
Ran system for a couple of days.
I cooled system. Opened rear vent added water and allowed any surface oil to escape, as per instructions.
I then redumped the system and flushed.
I then refilled and added treatment again, same stuff and I left it in. It seems to work.
I have been told if it is really bad you may have to change return lines but so far so good.
Regards.
Regards.
cleaning one pipe steam pipes
What is the best method to clean one pipe steam piping if I think there are clogs n the system?0 -
don't have the answer
but i would be interested in it too! i'm sure my system has never been cleaned so i would like to do it just to do it.0 -
Check out our residential steam products
on www.rhomarwater.com
We have both a cleaner and a treatment product. They are also listed in Dan's Buy, Sell, Show section.
Hope this answers some of your questions.0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
