Consolidated Furnaces
Glen
Member Posts: 854
but this is what is readable
Furnace Consolidated Industries
Model MDA 080 PH3R
Ser 950927375
Smart valve # - SV 9500 8619 (LPG)
Model MDA 080 PH3R
Ser 950927375
your experiences???
I thought it would be a simple service call to a summer cottage - no heat. Turns out to be a consolidated furnace - and on checking for a gas valve replacement - I am told it is no longer produced and I am advised to shut it down and disable because of the risk of spontaneous fire. Would any one have further info on this?0 -
Consolidated
Went into receivership around 1995, their interests were picked up by Texas Furnace.
This link is the contact info..maybe they can help. I know I can still get parts here in Ontario through Olsen, they carried the Mini Max made by consolidated.
http://www.texasfurnace.com/Contacts.htm
Mitch
Glen what is the
make and number of the gas valve, maybe I can help you find a replacement?0 -
be sure to check HE for leaks - very common on these where the secondary connects to primary exchanger as for gas valve isn't that a standard smartvalve0 -
Your local Johnstone
Johnstone has a cross for that valve. I service more than a few of that brand around here and the only thing I have trouble finding is the condensate trap. Pretty much everything else is standard off the shelf type parts. They did have a fair amount of HX problems due to the joint between the primary and secondary HX coming apart.0 -
Glen what is the letter
after SV9500 is it an M or H. That is a Generation I SmartValve (no longer made) which is replaced by a Generation II valve.0 -
The best I can come up with is
a replacement by SV9501M 8129.0 -
the letter -
was just a dark smudge. Unable to read it. The GV you suggest - is this a generic smart valve?0 -
I took your numbers and cross
referenced to Honeywell cross reference manual I have.0 -
thanks
I will order one this morning.
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 968 Plumbing
- 385 Solar
- 15.3K Strictly Steam
