Convert a radiator to underfloor
Timco
Timco Member Posts: 3,040
Radiant floors use less temp than your rads, and you would need a seperate circulator and a mixing valve for this. I would think kits that are available are for an entire system, and not advisable for the HO with no experience to install. Best to find a pro for this...
Tim
Just a guy running some pipes.
