Barber-Coleman
jp_2
Member Posts: 1,935
you are right, I was thinking of Allen Bradley for some reason????
Info on Barber-Coleman controls
Hi all,
Is there a place online to get Barber-Coleman info on their Actuators and drives?
I am working on a MP-471-100-0-2 actuator with a CP8301-120-1 solid state drive.
Thanks
Don in MO0 -
http://neccdelivers.com/_LINKS/linkframe14.htm
A good place to start anyway. Barber Coleman info is difficult to find ...I believe they were eventually bought by Invensys , and it's weird that you don't see Barber Coleman listed on the Invensys site.0 -
barber coleman
I believe is own by Rockwell International.0 -
Valve Selection Guide
Don...please see your other post where I'm trying to get valve assembly info for you. I can probably get the most updated Valve Selection Guide from my old company...or at least find somewhere you can order it from.
Also...cut sheets should be available. Some cut sheet info is in the old Siebe/Barber-Coleman catalogs. I found the wiring diagram for the CP-8301 interfaced with the MP-400 series actuator. I could scan this and post if you want0 -
Barber-Coleman is now
T.A.C. a division of Schnider Electric. Sold about a year or so ago from the Invensys Group. I used to work there 3 years ago. Good luck getting info.
http://www.tac.com/Navigate?node=1437
B-C, Invensys, etc.
BOSTON - July 31, 2006 - Schneider Electric, parent company of TAC, today announced the completion of the acquisition of Invensys Building Systems (IBS), a division of Invensys Controls with operations in North America and Asia. IBS will merge with TAC, a world leader in building automation, security systems and energy solutions. This follows the merger with Invensys ABS EMEA in 2005; revenues for the combined company are forecasted to reach approximately US $1.3 billion in 2006.
Invensys included: Barber-Colman, Robertshaw & Siebe. I can't find evidence Rockwell ever was involved w/ B-C, but it's possible.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
