need used viessmann burner
Glen
Glen Member Posts: 854
Hansa makes an excellent burner as well that works as well as the other two mentioned. As an option ...
  • SpeyFitter
    SpeyFitter Member Posts: 422
    Was wondering if anybody would have a motor or the burner assembly for a BE-46 oil boiler. The burner model is VEI-O-46.I cannot seem to find parts to replace the motor help please. bill.
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    Help
    You're not likely to find a used burner. You may have to replace with a new chassis burner. Try calling Viessmann tech services at 1-800-288-0667 in Warwick, RI. They may be able to help.
  • Glen
    that motor -
    Burner motor
    PN 7072 172
    is no longer available (no old stock kicking around the big V either) - and the next gen (VEC) may not fit. The above post may be correct: a new chassis burner from Viessmann or Riello is required. Or possibly rewind/rebuild the existing.
