need used viessmann burner
Glen
Member Posts: 854
Hansa makes an excellent burner as well that works as well as the other two mentioned. As an option ...
Was wondering if anybody would have a motor or the burner assembly for a BE-46 oil boiler. The burner model is VEI-O-46.I cannot seem to find parts to replace the motor help please. bill.There was an error rendering this rich post.
Help
You're not likely to find a used burner. You may have to replace with a new chassis burner. Try calling Viessmann tech services at 1-800-288-0667 in Warwick, RI. They may be able to help.
that motor -
Burner motor
PN 7072 172
is no longer available (no old stock kicking around the big V either) - and the next gen (VEC) may not fit. The above post may be correct: a new chassis burner from Viessmann or Riello is required. Or possibly rewind/rebuild the existing.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
