LP metering
Jim Davis_3
Member Posts: 578
I do believe in the past these were available but only through mobile home parts and equipment suppliers.
LP metering
I have a ranch with multiple out buildings on one propane tank. I would like to do alittle experiment and compare the gas consumption between 2 buildings. I was wondering if there are any inline meters other than the traditional big grey outdoor meter. I am invisoning a small inline gauge? Any thoughts.
Thanks Jeffrey0 -
Try your local
Victory/F.W. Webb or RAy Murray outlets who do a lot of business with the LP gas folks.0 -
I was at a Propane
Assoc. dinner this evening and talked to the rep from Victor Supply/F.W. Webb he does not know of any device other than a regular gas meter to measure gas flow.0 -
Data Logger
I am wondering if you could not parallel off of the gas controller or Thermostat and read total run time. Then you could do a little math an come up with gas consumption.
Best Wishes J.Lockard0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
