LP metering
Jim Davis_3
Jim Davis_3 Member Posts: 578
I do believe in the past these were available but only through mobile home parts and equipment suppliers.
  • Simply Rad_2
    Simply Rad_2 Member Posts: 171
    LP metering
    I have a ranch with multiple out buildings on one propane tank. I would like to do alittle experiment and compare the gas consumption between 2 buildings. I was wondering if there are any inline meters other than the traditional big grey outdoor meter. I am invisoning a small inline gauge? Any thoughts.
    Thanks Jeffrey
  • Try your local
    Victory/F.W. Webb or RAy Murray outlets who do a lot of business with the LP gas folks.
  • I was at a Propane
    Assoc. dinner this evening and talked to the rep from Victor Supply/F.W. Webb he does not know of any device other than a regular gas meter to measure gas flow.
  • jim lockard
    jim lockard Member Posts: 1,059
    Data Logger
    I am wondering if you could not parallel off of the gas controller or Thermostat and read total run time. Then you could do a little math an come up with gas consumption.
    Best Wishes J.Lockard
