wye strainers
hot_rod
Member Posts: 26,599
I'll find a way to get Caleffi to you. They have great fill valves, zone valves and other quality components.
hot rod
hot rod
what type of wye strainer
What type of mesh wye strainer is every one using to protect the heat exchanger on a mod con. I know this topic has come up before.0 -
check out the Caleffi DirtCal
better dirt removal without the pressure drop. Most Y strainers have a very small cross section area to plug. The Caleffi captures and allows dirt to fall into the lower chamber.
www.caleffi.us/caleffi/en_US/Site/Products/Product_news/args/detail/~Details~News~news_detail_0000243/type/newshome/index.sdo
hot rodBob "hot rod" Rohr
Spirotherm
Spirotrap is another0 -
Spirotrap
We have been using the Spirotrap. When we first started installing mod-cons we used wye strainers. Spirotrap makes cleaning much easier.0 -
HotRod
I have been reading about the Callefi line for years but none of the supply houses around here have them. They don't even have Spirotrap. I have to order 2 at a time so I always have one in stock. Do you have a contact for the Caleffi line?0 -
Caleffi
We are in eastern Pa. The Lehigh Valley area.0 -
hydor separator
Thanks guys, Totallt forgot apout the spirotrap. I am going to go with the B/G hydraulic separator instead. This will be a great application for its use we are using a knight boiler and it is feeding cast iron rads. I will post pics when project is completed.0 -
hydor separator
