wye strainers
hot_rod
hot_rod Member Posts: 26,594
I'll find a way to get Caleffi to you. They have great fill valves, zone valves and other quality components.
hot rod
  • what type of wye strainer
    What type of mesh wye strainer is every one using to protect the heat exchanger on a mod con. I know this topic has come up before.
    check out the Caleffi DirtCal
    better dirt removal without the pressure drop. Most Y strainers have a very small cross section area to plug. The Caleffi captures and allows dirt to fall into the lower chamber.
    www.caleffi.us/caleffi/en_US/Site/Products/Product_news/args/detail/~Details~News~news_detail_0000243/type/newshome/index.sdo
    hot rod
  • Tom Hopkins
    Tom Hopkins Member Posts: 554
    Spirotherm
    Spirotrap is another
  • RianS
    RianS Member Posts: 104
    Spirotrap
    We have been using the Spirotrap. When we first started installing mod-cons we used wye strainers. Spirotrap makes cleaning much easier.
  • RianS
    HotRod
    I have been reading about the Callefi line for years but none of the supply houses around here have them. They don't even have Spirotrap. I have to order 2 at a time so I always have one in stock. Do you have a contact for the Caleffi line?
  • RianS
    Caleffi
    We are in eastern Pa. The Lehigh Valley area.
  • hydor separator
    Thanks guys, Totallt forgot apout the spirotrap. I am going to go with the B/G hydraulic separator instead. This will be a great application for its use we are using a knight boiler and it is feeding cast iron rads. I will post pics when project is completed.
  • hydor separator
