domestic hot water
a series of tankless water heaters....two or 3..kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • jim_155
    jim_155 Member Posts: 4
    domestic hot water
    i want to install the most efficient domestic hot water system in my house.i need to draw 12gpm for ten minutes then a continuos 6gpm.i have low pressure nat.gas.what is the best way to do this? thanks jim.
  • Southside
    Southside Member Posts: 20
    Ummm, define "most efficient"
    If you are looking at input btu/gallon or $$$/gallon? A 6 gpm instant with a couple storage tanks with heat maintenance may be the lowest $$$ and not too bad for input BTUs. A large boiler and a couple or 3 indirects might cost a little more but be more efficient in terms of BTUs.
    Or as another poster suggested, just line up several instant heaters and pay $$$$$$$$$$$$$$$ up front.
  • jp_2
    jp_2 Member Posts: 1,935
    6 gpm
    that 180,000 btu's per hour??
    what are you doing? how long do you need 6gpm? how often do you require these draws?
  • ScottMP
    ScottMP Member Posts: 5,882
    I have a shower head
    and a handheld. I use the handheld like a body spray. At 2.5 each 5 gpm is not that outragous ... Is it ??
    Scott
  • Bruce M
    Bruce M Member Posts: 166
    Noritz
    You can use a Noritz 1321 series tankless heater. You can see them here.
    http://www.noritz.com/homeowners/products/
  • ALH_4
    ALH_4 Member Posts: 1,790
    Lochinvar Armor
    The Lochinvar Armor costs more, but it's a lot more efficient than a Noritz.
  • Home Depot Employee
    Home Depot Employee Member Posts: 329
    Takagi
    Depending on your incoming average water temp and gas capacity available along with outlet temp required you may be able to use 2- Takagi TK3. These units come with the cord required to sequence the operation. I have 9 GPM and mine work Great!!!!
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,011
    Whatever...
    ... you do, add a GFX shower heat exchanger and capture 60% of the heat going down the drain. Then you can buy less heating equipment ;~)
    Yours, Larry
  • Shane_2
    Shane_2 Member Posts: 200
    The GFX heat exchanger sounds like a good idea, but what about Legionnares disease and the water sitting in that drain when not in use?
  • Larry Weingarten
    The GFX is a double wall heat exchanger, vertically oriented. The waste line part of it drains and the clean water side is basically like any other cold pipe in a house and is flushed with each use. I have not heard nor do I think Legionnaires is a risk with the GFX. So, don't worry, be happy ;~)
    Yours, Larry
  • Mike Dunn
    Mike Dunn Member Posts: 189
    I like it
    This thing is cool. I will be installing one in the next house project I do for sure.
