domestic hot water
kevin coppinger_4
Member Posts: 2,124
a series of tankless water heaters....two or 3..kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
domestic hot water
i want to install the most efficient domestic hot water system in my house.i need to draw 12gpm for ten minutes then a continuos 6gpm.i have low pressure nat.gas.what is the best way to do this? thanks jim.0 -
Ummm, define "most efficient"
If you are looking at input btu/gallon or $$$/gallon? A 6 gpm instant with a couple storage tanks with heat maintenance may be the lowest $$$ and not too bad for input BTUs. A large boiler and a couple or 3 indirects might cost a little more but be more efficient in terms of BTUs.
Or as another poster suggested, just line up several instant heaters and pay $$$$$$$$$$$$$$$ up front.0 -
6 gpm
that 180,000 btu's per hour??
what are you doing? how long do you need 6gpm? how often do you require these draws?0 -
I have a shower head
and a handheld. I use the handheld like a body spray. At 2.5 each 5 gpm is not that outragous ... Is it ??
Scott
Noritz
You can use a Noritz 1321 series tankless heater. You can see them here.
http://www.noritz.com/homeowners/products/0 -
Takagi
Depending on your incoming average water temp and gas capacity available along with outlet temp required you may be able to use 2- Takagi TK3. These units come with the cord required to sequence the operation. I have 9 GPM and mine work Great!!!!0 -
Whatever...
... you do, add a GFX shower heat exchanger and capture 60% of the heat going down the drain. Then you can buy less heating equipment ;~)
Yours, Larry0 -
The GFX heat exchanger sounds like a good idea, but what about Legionnares disease and the water sitting in that drain when not in use?
The GFX is a double wall heat exchanger, vertically oriented. The waste line part of it drains and the clean water side is basically like any other cold pipe in a house and is flushed with each use. I have not heard nor do I think Legionnaires is a risk with the GFX. So, don't worry, be happy ;~)
Yours, Larry0 -
I like it
This thing is cool. I will be installing one in the next house project I do for sure.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
