fuel oil flow meter
BC
BC Member Posts: 28
I second the hour meter idea - much cheaper and pretty darn accurate, especially if you check it with the tank gauge. I've been doing htis for 5 years and the data is pretty consistent (.26 gal/degree day for me, big uninsulated victorian house with an old coal boiler converted to oil). It also matches up pretty well with my heat loss calcs for the house.
  • tom_49
    tom_49 Member Posts: 267
    fuel oil flow meter
    Anyone out there know of a cost effective, inline flow meter for a residential oil burner. I'm trying to watch my actual daily consumption in comparison to degree days.
    thanks.
  • mark  smith
    mark smith Member Posts: 112
    they are 4-600$, made for commercial use, obviously
    what do you consider cost effective..???
  • tom_49
    Mark, are they $150.00 each and do I have to buy 4.
    what brand/model, $150.00 seems reasonable.
  • Ted Robinson
    Ted Robinson Member Posts: 126
    Useage meter
    I have a cheaper way - I have been using a clock device in parallel with the burner motor, that logs running hours in 1/10's. I know my nozzle size and the useage matches the tanks refills.
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    wire an hour meter to the oil valve --very accurate i have done this in a few multi-family dwellings where they split the heating costs--an hour meter on each pump
