1 1/4\" iron pipe
Anthony Menafro
Member Posts: 198
Amen to that sentiment brother! I've seen many people use those protectors just to remove them after they fail pressure tests.
Anthony Menafro
Anthony Menafro
1 1/4 \" iron pipe
anyone know if you can buy 1 1/4" bi pipe longer than 21'?
i'm hopeing to find about 35' lengths but i doubt it0 -
pipe
try long island pipe supply or davidson pipe in brooklyn. if it can be had, they can get it.0 -
I forgot to say i'm in ma.but i'll keep them in mind if no one local. thanks0 -
How would you haul and carry
a stick of 1-1/4" that long
hot rod
I'm hoping...
you intend to use it as a flag pole:-)
How you going to ship it?
Once shipped, how you going to bend it around the corners of the house to get it into place?
I'm sure its possible, but the industry standard is 21' lengths. Asking a mill to ship a 35 foot piece of pipe could get REAL Expensive. This is why they make couplers... ;-)
ME0 -
going into a 30' chase for a fill and vent cust wanted no cplg told him didn;t think it was possible. can get in chase to hang and work on it but he was hopeing for one peice0 -
Weld it together
I Know...
... that you can get double-lengths of steel pipe in larger sizes like 10". I'll bet you can get the smaller diameters as well. Depending on the grade of pipe you're looking for, you might get better delivery on standard lengths that are threaded & coupled. Note that the "couplings" on pipe shipped like this are just thread protectors. They're NOT proper pipe couplings - they've got straight thread, not tapered, and they're not made to the same standards as a real coupling. Take the thread protectors off, and toss them in the scrap bin.0 -
Thats got to be the answer .There is no other practical way to achieve a 35 foot length with out a coupling .0 -
use copper with brazed joint?
I don't weld, but as was suggested, I bet yu could get it done pretty cheap, specialy if you bring the pipe to the welder. You can get any length you want, but you will PAY for it.0 -
cplg or welding would be fine i thought run it by them again0 -
a bad idea
Sometimes you gotta tell a customer what he REALLY wants. i was under the impression there was a bonifide reason for the random length not a impractical idea by a moron wasting everyones time. sometimes ya gotta cut these **** off at the pass,John. they can make you nuts with their nonsense. i bet he would not be willing to pay the true added expense for his hair-brain scheme.when you give the revised price ,they say " oh that's o.k. the coupling is fine. " good luck.0 -
it would be a bummer if you neededd one 35'3\"
habby home owner would have to pay you to thread on a nipple God Bless America where else would someone even think of something like that man thats good:) "i Like It !":)0 -
1 1/4 pipe
If you are in mass. try Grant steel in Holbrook. They used to supply me with 40 footers in 3",4" 6" I don't know about smaller diameters.
Chuck0 -
Easy Mark,Skycrane it in with a Sikorsky.
Done Deal:)0 -
35 ft lenth
just tell the customer that the supply houses pipe streacher is broken
Looks like...
We have a NEW contender in the Pole Vault event....:)0 -
a no-miss barrel for a block shoot?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
