Aqua stat problem?
ChasMan
Member Posts: 474
FWIW, My Guage says the water is 240 degrees. THe Aquastat says it is 180.. My Candy thermometer says its about 175...
Since I hear no hissing, Im guessing my Tri Guage is busted.
I set the aqua stat to 180 and the gauge never gets over 140 or so. WM CGA Gold. Can I raise the aquastat until the mfg's gauge reads 180? Mounted right where they said to mount it. I should mention the unit does cycle off.
Thanks, TJust a guy running some pipes.0 -
It might be a gauge problem.0 -
Gauge is honeywell...3 months old now.Just a guy running some pipes.0 -
dilemma
That's the question Tim. which is the more accurate ? install two more gauges and conduct a test pattern. lol that is if you got nothing else to do.0 -
maybe I'll fill a cup with boiler drain water and check it's temp...seems easier than draining and installing addl gauges....har har har...thanks anyway.
Just found out mine is the opposite...to get 180* water, I needed to set the aquastat to about 210* or so...I double checked it with a digital thermometer straight out of the boiler just after it cycled. Pressure is just fine as well.
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
