air valve
joe plumber
Member Posts: 2
would a air valve work in a 2 pipe syst.
have 2 rads. twined in and not getting hot.
changed 2 traps and valve... stm going to all other rads
help....
help....
would it work
help....0 -
No!
Find out why the rads don't get hot. Disconnect the unions at the traps and see if they heat. If so, you have pressure in the returns- possibly from bad traps elsewhere in the system- or a water pocket in the return. If not, something is blocking the steam supply- possibly a water pocket there too.
- 167 Indoor-Air Quality
