disturbing noise and main vent
Good day,
The length of the header, from boiler to end, is 43 feet. The diameter could be 2.5 or 2 -inch. The radiators, I don't know on EDR sq. ft, but I installed these cheap adjustble air vent (from home depot) on most radiators. What size will be the main vent? Any suggestion for the air vents on radiators.
I replaced the 1.25 inch diameter clogged return line with 1 inch dia. copper pipe, and I still hear hissing sound from radiators, an irritating banging sound located near at the end of the header pipe every heating cycle.
Please advise.
Thank you.
