Hot surface Igniter for Dunkirk Q90-175
Mitch_4
Member Posts: 955
It was good to talk to you about this and hopefully everything checks out. Please let me know the results.
Mike
Mike
Igniter for Olsen (Dunkirk) Q90-175 boiler
I have a Olsen Q90-175 boiler (Dunkirk in the US) which is 1 year an 1 month old and on Saturday - the hot surface igniter became defective and unfortunaly for me - in my city - Winnipeg commonly refered to as Winterpeg for it's really cold winters - no one stocks the igniter replacment kit so my question is - does anyone know of a third part or cross for this igniter? The defective igniter has a sticker that says Norton on it, Model 271-R
I do have two on order (one for backup)and how long should one expect an igniter to last?
LuckyI was smart enough to keep my old faithfull boiler in line as a backup so I do have heat.0 -
Starlite
I have a cross-reference sheet from Starlite. (www.ignitersystems.com)and it lists the following Norton ignitors.
201A,271A,201D,271D,201N,271N,271NQ,271Q,201W,271Y, 271 Y or M. I did not see a 271 with an "R" suffix.
We just replaced a 271Y with a Robert-Shaw 41-406 and was just the ticket. You might download their cross-ref sheet or give them a call.
Regards,
PR
Thanks PR
it actaully looks like the Rheem 62-22669-92 or pretty close
I will have to measure to see0 -
If you have a fax number,..
I will fax you the cross-reference I have. It doesn't look like it is available on-line, but this is what my supplier uses as a reference.
Regards,
PR
Hi PR
Hope you do not mind doing this
1-204-284-9989 or email rdmco@mts.net
thanks0 -
Tech support
Hi Rick.
My name is Mike Breault and I do technical support for the ECR International - Olsen Division products.
I would like to talk to you about some things to check on the unit, as well as where you can locate a replacement part. You can reach me at 519-627-0791 ext 228.
Mike0 -
Rick
Tried faxing, go a busy signal. Let me know.
Regards,
PR
Hi Paul
Received your fax - very much appreciated and I will reveiw and post back
again thanks
Hi Mike
Than you for responding - It is about 4:37 Winnipeg time and I am sure you have headed home as it's 5:37 your time - I will try you but if I miss you, I will get you in the AM
Rick
Winnipeg0 -
can almost guaranty
if you call Dunkirk, in Dunkirk N.Y. they will either send one out or give you a replacement no.
alot of ignitors have been standardized. Don't know about the Norton though. If that hot surface ignitor is touched, the oil from your hands will create a hot spot nd they will burn out, other wise they are generally pretty reliable0 -
q-90
Had the same problem with the Q 90 that ignighter is a strange configuration and we had to order a new one and supply electric const heaters to keep the house from freezing as this was a replacment boiler for a lenox complet heat and were not yet in stock0 -
Jeff-
Don't know if this has any resonance here, but when Trane came out with the Voyager, oh, a few years ago (kinda giving away my age here), they used a spiral type hot surface ignitor that failed on a fairly regular basis. Like once a year. If even. They first told us that we as techs were touching it, and the oil from our fingers caused hot spots. (Did that mean that when they were installed at the factory that someone touched them there?...)Anyway, a few years later, they said if the unit was cycled on after a long set-back with a Really cold outdoor temp, the thermal shock, or possibly a drip of water from condensation was wiping them out-they then offered a kit which sent a "trickle" charge of voltage to the ignitor all the time to keep it "warm", until ignition voltage was neede. Finally, they figured out that the spiral type ignitor was a little, well, poorly designed, and changed the type used. Long story short, I don't rub ignitors through my fingers to test the Gods, but I don't buy the oil theory-could well be something else. Been there, bought the T-shirt. (heck, used to change the Voyager ignitors with Latex gloves-they sold em at my supplier! Little good it did, though...) Doubt this helps do anything but raise doubts, but what the heck-0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 969 Plumbing
- 385 Solar
- 15.3K Strictly Steam
