exploding pex tubing
tim smith
tim smith Member Posts: 2,886
Probably exceeded pressure temperature limit.
  • Jerry_15
    Jerry_15 Member Posts: 379
    pex tubing
    Has anyone had an experience with good quality barrier Pex blowing out in the middle of the pipe? Long ways away from the boiler. Running dandy for two years. Don't want to name the manufacturer quite yet. Luckily there was somebody home. Any thoughts?
  • Home Depot Employee
    Home Depot Employee Member Posts: 329
    Twice
    Ive seen it blow up on two occasions:
    Once when a section of pex was capped and pumped with high pressure air. If I recall it ruptured at about 1800 psi and the caps and SS pinch rings held.
    Second time when it froze in two spots and blew out in the middle.
  • Plumdog_2
    Plumdog_2 Member Posts: 870
    yes
    when a frozen system thawed out and ran wild without feed or low water cut-off. The steam burst the pex.
  • mark_101
    mark_101 Member Posts: 12
    pexplosion
    was this pex with an oxygen barrier or was this pex,aluminum,pex type tubing. i have had a 20 foot piece of pex,aluminum,pex that i happened to hold by a section that was all distorted as i installed it. i looked at the spot where i felt the deformity and noticed that the aluminum was all twisted and bunched up and there was a spot where there appeared to be no aluminum oxygen barrier and the pex beneath it was very thin as i could depress it very easily.
